I am using a dht 11 temp sensor and would like to change 72.00 deg to 72 deg to save display digits. I have used round to eliminate the decimals from jumping around but want to drop the .00 digits. Is there a node to do this.
Use the Pad with Zeros node and set it to 2 as in two digits.
format-number with DIG = 0 will do the same thing.
Thanks for the help i used format and it worked
