Where is the code block for generating a tone through a buzzer?
Where can I get the library for the code block?
GD
GD
You can search https://xod.io/libs for “buzzer” or “tone”. There is also a buzzer node in https://xod.io/libs/marcoaita/malibrary/ that doesn’t show up in those searches.
You can also write your own based on code provided in another thread on this forum: Figuring out how to make a buzzer node
