So I know arduino has a frequency of about 400 herts on it’s pwm outputs, but how do I lower that value to something lower? I want about 100hz, not 1khz
hi, there are some arduino libraries for softpwm, but I’m not sure I can do it.
Maybe someone with C++ domain could do it. @bradzilla84
here the link
https://github.com/Palatis/arduino-softpwm
See https://playground.arduino.cc/Main/TimerPWMCheatsheet
See the “divisor” table in there.
It should be pretty easy to make a XOD node to modify PWM rates, but be careful: TCCR0B also controls the millis() timer, so clocks would be off! Also, there is something about prescale values for UNO’s.
So, you should be able to get to ~122Hz. Your choices of the rate are very limited though.
If you can’t figure it out, you can ask me, but it may take me a while to write a patch.
