Optical encoder
Hi,
I am building a rig to measure electrical cable.
So far i have an incremental optical encoder with 3 output signal wires with a Arduino UNO.
With only two wires (signal A and B) connected i have a serial output using the Arduino IDE but i want to use this in XOD to be able to manipulate the data and display on a simple LCD screen.
I am still new to XOD so could anyone point me to a node/library for this or how i can import code to XOD?
Hey john-barry !
Checkout the https://xod.io/libs/nkrkv/encoder/ library.
This library contains base nodes for any incremental encoders, both magnetic and optical.
That was an easy solution
Somehow it says library not found when i’m signed in
But anyways thanks for the help!
