Node "random" (nkrkv/random/random) does not work
Hello,
The node “random” (nkrkv/random/random) does not work under XOD version 0.32.1 and board Arduino Uno R3.
Get always the error message shown in uploaded picture “error message.png”.
Can someone solve this problem or does anyone know a solution?
Thanks in advance for a quick response.
PS: Similar to post "Do not work node “random” (Do not work node "random") from moi-yashik2 dated Nov ’19.
in the example replace analog-input with analog-read
don’t drag it, open with double click
Tthank you cesars, now it works perfectly.
Dear XODers,
i have a problem with the random node too and need help.
Your
Chris
Compiling sketch…
“C:\Users\Chris\xod\packages\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\Chris\xod\packages\packages\esp8266\hardware\esp8266\2.4.3/tools/sdk/include” “-IC:\Users\Chris\xod\packages\packages\esp8266\hardware\esp8266\2.4.3/tools/sdk/lwip2/include” “-IC:\Users\Chris\xod\packages\packages\esp8266\hardware\esp8266\2.4.3/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\Chris\AppData\Local\Temp\arduino-sketch-A62E96521E8F9A5189A9E4B861BDBCD1/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1R1 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_WEMOS_D1R1"” -DESP8266 “-IC:\Users\Chris\xod\packages\packages\esp8266\hardware\esp8266\2.4.3\cores\esp8266” “-IC:\Users\Chris\xod\packages\packages\esp8266\hardware\esp8266\2.4.3\variants\d1” “C:\Users\Chris\AppData\Local\Temp\arduino-sketch-A62E96521E8F9A5189A9E4B861BDBCD1\sketch\xod_1592505551808_sketch.ino.cpp” -o “C:\Users\Chris\AppData\Local\Temp\arduino-sketch-A62E96521E8F9A5189A9E4B861BDBCD1\sketch\xod_1592505551808_sketch.ino.cpp.o”
C:\Users\Chris\AppData\Local\Temp\xod_temp_sketchbookIQsIAu\xod_1592505551808_sketch\xod_1592505551808_sketch.ino: In function ‘void xod::nkrkv__random__random::evaluate(xod::nkrkv__random__random::Context)’:
C:\Users\Chris\AppData\Local\Temp\xod_temp_sketchbookIQsIAu\xod_1592505551808_sketch\xod_1592505551808_sketch.ino:1357:31: error: invalid conversion from ‘long unsigned int*’ to ‘unsigned int*’ [-fpermissive]
int rnd = rand_r(seedp);
In file included from C:\Users\Chris\xod_packages_\packages\esp8266\hardware\esp8266\2.4.3/tools/sdk/libc/xtensa-lx106-elf/include/stdlib.h:11:0,
from C:\Users\Chris\xod_packages_\packages\esp8266\hardware\esp8266\2.4.3\cores\esp8266/Arduino.h:27,
from C:\Users\Chris\AppData\Local\Temp\xod_temp_sketchbookIQsIAu\xod_1592505551808_sketch\xod_1592505551808_sketch.ino:18:
C:\Users\Chris\xod_packages_\packages\esp8266\hardware\esp8266\2.4.3/tools/sdk/libc/xtensa-lx106-elf/include/stdlib.h:197:12: error: initializing argument 1 of ‘int rand_r(unsigned int*)’ [-fpermissive]
int _EXFUN(rand_r,(unsigned *_seed));
\packages\esp8266\hardware\esp8266\2.4.3/tools/sdk/libc/xtensa-lx106-elf/include/_ansi.h:65:30: note: in definition of macro ‘_EXFUN’
#define _EXFUN(name, proto) name proto
Error: exit status 1
Compilation failed.
Compilation failed
Solved for Wemos Board
chris-cross/random-wemos-d1@1.0.0
Greez
Chris
