Hello and welcome.
Well, you need something like:
But, there’s no such node as avg-measure in XOD standard library (yet). No problem, you can make your own:
The basic idea is to trigger N readings and store their sum with count node. When N readings are accumulated, pass the result of the “sum / N” to the node output.
I didn’t check it for myself but hope I gave you the necessary direction. A xodball of the project is attached: lets-make-a-beer.xodball (7.3 KB)
