https://xod.io/libs/e/mcp4725/
The library has a single node:
For this or similar breakout boards.
Made an additional LFO for my Arturia Microbrute with it, pretty happy with the results so far.
Hi evgenykochetkov,
I was happily using your wonderful Library for a torque controlled servo until Xod deprecated the else if(byte) node causing the dac to no longer connect via i2c, Xod recomment: “Use the generic xod/core/if-else instead”, however simply swapping out the node and keeping the input values does not solve the problem… As I am not familiar with writing libraries I have hit a wall with this problem.
Could you offer any advice?
Kind regards
Steve
