Is there a way to run a small motor without the use of any H bridges, transistors, etc?
(one direction is fine for me)
Because if i put the pins into ground and 5V it works but i cannot regulate the speed.
And when i try to put the +pin into an analog or digital it does not work (but makes noises).
I tried the H bridge node, led, etc…
No luck.
