Local compiler and libraries
Hello I have just installed XOD and like it very much I’ve come from node-red so similar setup but feel that XOD is a lot more powerful once I get used to it, I build robots as a hobby and this is going to be of great help.
I have an issue tho the compiler is limited to 100 cloud uses how do I change this to a local compile?
and I have noticed there is the capability to add libraries where do I find what libraries are available?
I’m pretty sure you get more compiles if you login. Just unchecking cloud compile box compiles locally.
https://xod.io/libs/ lists available libraries. Once you find one you want to try, go to XOD and select File > Add Library, then type in <username>/<library> in the search bar.
