Hi hoping anyone can shed some light on this library and this example
First do all of these nodes work correctly in the library there isn’t any know bugs i should no about? people have built up successful muilt stepper projects?
Second for my tests with the provide example code yes it runs 2 stepper motors at the same time goes to 1 position and then 2 the second position and stops
The only way for me to make this happen again is a full reboot of the code with the rest button and I thought it would be simple enough to add more positions by dragging out the multiposition-add node and type in the vales I want nope…
So yeah dose this work or is it broken or am I just completely using it wrong
All I’m looking for is have 2 steppers motors move at the same time at the push of a button two different positions in a sequence then stop and then run the sequence again at a push of a button
Any help would be wonderful thanks
