I don't see current value on servo
I think I should to see 0.34 on the node from position-value - VAL
but I see only 0.52 and this value don’t changes when I change value from potentiometer. Also servo is moving.
How I can fix it?
And what exactly mean Pmin Pmax in servo-device?
try pulse-on-change from map output to UPD
You are creating 2 different servo devices attached to the same pin. servo includes code to create a servo & move it, then you create a different servo device and request position of it. You can’t use the xod-dev/servo/servo short-cut if you want to be able to query the position later. You will need to create a single servo device & pass it to both rotate and position-value. Open the servo patch, and you will see how it is actually coded.
FYI: position-value is just returning where you’ve asked the servo to move to. Standard servos have no way to report their actual position.
