What do you have wired to pin 0?
Hi gweimer , I don’t have anything at the moment . I just ran the simulation before I wire up some buttons and a led . The or output shows true when the prs values of the button show false . Sorry I’m new to this and not sure if you should only tweak values with the tweak node or you can change values in the hardware nodes while running a simulation
Simulator cannot be used with nodes for physical devices (buttons, POTs, LEDs, etc.). There is no way for the simulator to know what a physical device is doing.
Ok cheers , thanks for the help
