Hi everyone, I want to contact @wayland. I know you work a lot with esp32.
There is an esp32 in the list of boards, but there is no box icon in front of it. When selecting from the list, it cannot find the board connected to the port. I tried to insert a link in the “extra” file. Nothing has changed.
Instructions for adding the esp32 board can be found here:
Hope this helps!
Thanks for the quick reply! I will definitely try now.
Dear @wayland, I would like to ask for one more moment of your attention. After adding the link to the “extra” file, there are two esp32 Dev boards in the board list. But when choosing, no one sees the connected board. Maybe I choose something wrong (I tried different USB conductors)?
Problem with adding ESP32 board solved! (installed the cp21xx driver for windows 10). I chose “ESP32 Dev Module”. However, the test with the built-in LED on pin d2 via PWM fails, everything only works when I use digital-write as a blinking signal output. Mr. @wayland help me figure out what’s wrong.
