Different result, simulation vs debug
Why get a different result? If I simulate it the result is different than if I charge it on the board.
What am I wrong about?
struct State {
{{ GENERATED_CODE }}
void evaluate(Context ctx) {
    auto state = getState(ctx);
    auto str = getValue<input_IN>(ctx);
    char _str[16];
    dump(str,_str);
    emitValue<output_OUT>(ctx, atoi(_str));
Simulation
Debug
Fascinating…I get the exact same result with Arduino UNO.
Looks like some kind of overflow problem. It works through 32767, but 32768 displays as -32768. It works for your example if you replace atoi() with atof().
Thanks for trying it, I don’t know if my code will be fine
Use atof() instead of atoi() if you want larger numbers (didn’t know if you would notice my edit above).
later I will do some tests, this node was for the melody library, but there I only used one bit, I had no problems.
Now trying to do something for an array I found this and I get disoriented, on top of that I understand little about C ++.
thanks
Yeah. I know nothing of c ++, if I did I would probably not even be using xod. I think the reason why I xod is because it allows me to easily program without knowing how to use a super complicated programming language.
Xod is also confusing enough to make me feel like I’m not a complete dummy using it. I’m forced to think about processes and understand what is going one and I love that.
Glad we have a work-around, but it does point out a bug/feature…simulation is using a different size int than Arduino board(s).
