Hi All,
I have just started playing with XOD and it seems very powerful. But I am having a problem relating how it works to old fashioned C (Arduino style).
In particular I have a code fragment that generates a PPM stream from an array of inputs. There is no coding required in the “loop()” section of the program to implement this. It just sets some registers (BTW this only works on Arduino Nano and Mega2560 to my knowledge) for timer1, and an ISR to increment the array counter. It works really well, but I don’t know if it can be implemented in XOD. I know zero about C++, and not much more about XOD.
I saw another post where you suggested copying the bespoke code into the code generated by XOD. This would certainly work but it would mean doing it every time the XOD patch is updated. Not a huge problem for me as there is lots of other stuff to implement that doesn’t require the PPM output generated (I could probably stick that in last, after everything else is working) but I still have the problem of populating the array and making it available to the ISR. Is that possible? Would I need to define it in the state{} section of the “not defined in xod” node? How do I reference it from another node (that does analog reads and generates the pulse width)? From what I understand of XOD so far this would not be possible.
For your perusal I’ve pasted the full code below.
Thanks, Ian
volatile unsigned int channel[9] = {2000, 2400, 2600, 2800, 3000, 3200, 3600, 4000, 21400};
volatile unsigned int ch = 0;
void setup() {
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
TIFR1 |= (1 << OCF1A); // clear any pending interrupts;
TCCR1A |= (1 << COM1B1); // Toggle on B compare
TCCR1A |= (1 << WGM10) | (1 << WGM11); // Fast PWM mode, TOP = OCR1A
TCCR1B |= (1 << WGM12) | (1 << WGM13); // Fast PWM mode, TOP = OCR1A
TCCR1B |= (1 << CS11); // 8 prescaler gives 500us tick size, i.e. 2 ticks per ms.
TIMSK1 |= (1 << TOIE1); // enable overflow vector
DDRB |= (1 << DDB2); // for Nano - turn on output pin 10 = OC1B (PB2).
//DDRB |= (1 << DDB6); // for Mega - turn on output pin 13 = OC1B (PB6)
OCR1B = 600; // for separator pulse of 300us - double for 8 prescaler
interrupts(); // enable all interrupts
ISR(TIMER1_OVF_vect) {
OCR1A = channel[ch] ;
ch = ( ch++ > 8) ? 0 : ch;
void loop() {
// put code to do analog reads, switch polling and whatever else is
// required to generate the pulse widths required, and store them in
// the “channel[]” array. The example will transmit 8 channels. The
// ninth element is the sync pulse (22500 - sum of all pulses and
// separator pulses) and must be recalculated for every frame.
