Are the port names different in XOD than what is labeled on the board? Ive tried using D0, D1, and D5 ports of Nodemcu board and none of them worked. Not sure what Im doing wrong here. During the upload phase to the board and about half way through the upload the led light will turn on but will turn off when the upload is finished.
Hi! uther2017
Can you please tell us what board model exactly do you use?
Also, the screenshot of your patch or loading/compiling error would help us to solve your problem faster. Thanks.
NodeMcu ESP8266 V3 Lua CH340
And at first i just used a digital write node set at a default of “true” and for pin “D1”. When that didnt work I tried the first Led tutorial and that didnt work either.
Also there is no compiling error. Everything uploads to the board normally.
Figure out the correct name of the ports and pins for the Board.
For example, here what I found on Web:
Using NodeMcu try to fire the “onboard” LED. It is “16” or “D16” in XOD.
Flash the board as the NodeMCU 1.0 (ESP-12E Module).
This patch works fine on NodeMCU devkit v0.9 (yellow pill) for me.
Unfortunately I can’t specifically test your board, I don’t have it.
I tried your patch and did the D16 port for the Nodemcu and did the upload. The upload said it was successful but the led light never came on.
edit : I just tried D2 for the pin and it worked! Now the led on the board is flashing. D5 on the board is D14 on XOD. So yeah it was all just a mapping issue and thanks for the link. That really helped.
Yes, the pin numbers are messed up and that’s a known problem (https://github.com/xodio/xod/issues/1529). For now you have to figure out the “true” number of GPIO in terms of the ESP8266 chip rather than in terms of NodeMCU.
Will this stop it from working with the esp8266 node for connecting to the internet in xod? When I tried to use one of the example nodes it gave me a compiling error when I tried to upload to the board. Its acted like it couldn’t recognize the board I was using
No, the pin numbering has nothing to do with internet connectivity.
The full verbatim output of the compiler with the error would help a lot. I can’t tell much without seeing what’s going wrong.
I get this when I tried to upload the Example-Get-Data-From-Dweet to it.
Error: exit status 1
Compilation failed.
Compilation failed
Command /opt/XOD\ IDE/resources/arduino-cli --config-file=/tmp/arduino-cliBI5BJc/.cli-config.yml compile --fqbn esp8266:esp8266:nodemcuv2:Debug=Serial,DebugLevel=COREWIFIHTTP_UPDATEUPDATEROTAOOM,FlashErase=all,UploadSpeed=9600 --verbose /tmp/xod_temp_sketchbookHwHgEb/xod_1575074907975_sketch failed with code 1
Quick Help
Select a node or patch to view its documentation article
You need to scroll up to see what the error message is.
This is the whole message.
Begin compiling code for the board NodeMCU 1.0 (ESP-12E Module)
Using board ‘nodemcuv2’ from platform in folder: /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3
Using core ‘esp8266’ from platform in folder: /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3
Detecting libraries used…
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/sketch/xod_1575082748426_sketch.ino.cpp -o /dev/null
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/sketch/xod_1575082748426_sketch.ino.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/CertStoreBearSSL.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/ESP8266WiFiMulti.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/ESP8266WiFiScan.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiClient.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiClientSecureAxTLS.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiServer.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiServerSecureAxTLS.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src/WiFiUdp.cpp -o /dev/null
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/sketch/xod_1575082748426_sketch.ino.cpp -o /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/preproc/ctags_target_for_gcc_minus_e.cpp
/home/uther/xod/packages/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch…
/home/uther/xod/packages/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/lwip2/include -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/tools/sdk/libc/xtensa-lx106-elf/include -I/tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DDEBUG_ESP_PORT=Serial -DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_ESP_OOM -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_NODEMCU”” -DESP8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/cores/esp8266 -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/variants/nodemcu -I/home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi/src /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/sketch/xod_1575082748426_sketch.ino.cpp -o /tmp/arduino-sketch-917D8478AF6365B53D68FB653DC35938/sketch/xod_1575082748426_sketch.ino.cpp.o
/tmp/xod_temp_sketchbookjNZ7GC/xod_1575082748426_sketch/xod_1575082748426_sketch.ino:4359:40: error: ‘A2’ was not declared in this scope
constexpr uint8_t node_44_output_VAL = A2;
Multiple libraries were found for “ESP8266WiFi.h”
Used: /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi
Using library ESP8266WiFi at version 1.0 in folder: /home/uther/xod/packages/packages/esp8266/hardware/esp8266/2.4.3/libraries/ESP8266WiFi
Compilation failed.
Compilation failed
Command /opt/XOD\ IDE/resources/arduino-cli --config-file=/tmp/arduino-cliV3n5VC/.cli-config.yml compile --fqbn esp8266:esp8266:nodemcuv2:Debug=Serial,DebugLevel=COREWIFIHTTP_UPDATEUPDATEROTAOOM,FlashErase=all,UploadSpeed=9600 --verbose /tmp/xod_temp_sketchbookjNZ7GC/xod_1575082748426_sketch failed with code 1
Quick Help
