Been trying to use the menu system by @bitrex (v1.1) but have been unable to get it to upload to the arduino.
I’m using an elegoo uno r3 and 20x4 LCD with i2c interface
Full log in attached .txt
XOD bitrex menu log.txt (91.5 KB)
Begin compiling code for the board Arduino Uno ![]()
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:1392:5: error: expected unqualified-id before ‘namespace’
namespace menu_base = ____menu_base;
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:1393:25: error: ‘menu_base’ does not name a type
using menu_base_t = menu_base::MenuBase;
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:1395:18: error: ‘menu_base’ does not name a type
using Type = menu_base::BiDirectionalList<menu_base_t*>;
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:1398:9: error: ‘menu_base’ does not name a type
menu_base::LeafMenuImpl<menu_base_t> leaf_menu;
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:1399:9: error: ‘menu_base’ does not name a type
menu_base::BiDirectionalPlainListView<menu_base_t*> leaf_menu_view =
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:1403:13: error: ‘Type’ does not name a type; did you mean ‘byte’?
typedef Type typeof_OUT;
byte
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:4472:20: error: ‘struct xod::bitrex__xod_menu_system_11__menu_controller::Node::ContextObject’ has no member named ‘_input_MENU_TREE’; did you mean ‘_input_TITLE_1’?
ctxObj._input_MENU_TREE = node_48._output_OUT;
_input_TITLE_1
C:\Users\danie\AppData\Local\Temp\xod_temp_sketchbookJQzRlK\xod_1660066239316_sketch\xod_1660066239316_sketch.ino:4472:47: error: ‘xod::Node_48 {aka struct xod::bitrex__xod_menu_system_11__concat_menu::Node}’ has no member named ‘_output_OUT’; did you mean ‘output_OUT’?
output_OUT
Compilation failed
