"/bin/avr-g++": file does not exist Compilation failed
Hi Everybody,
deloying an program, even the sample program returns the failure message “/bin/avr-g++”: file does not exist
Compilation failed
Arduino board is up to date V1.8.19
All packages are up to date.
does anybody has an idea how to solve this problem?
many thanks
My guess would be that avr-tools did not get installed properly. There are past discussions on how to fix this.
