Arduino due capable
Im having issues with getting my arduino due to run stepper motors via xod… can i wire up my due the same as whatever the nodes say to use or i chose to when programming? in other words, i assume most perimeters are based for uno but will that transfer over to the due the same? Thank you for the help.
Most of the time you can use the same pins, but if any pins require specific functionality (like PWM or analog), you will need to use pins on the new board that support that, so some changes may be needed. PWM support is most likely to be your issue if due has PWM support on different pins than the uno.
