HI can somebody help me?
I tray use UART with esp32 but nothing work ;(
I get error.
the gool is conect esp32 with grove LoRa Radio 868mhz that use uart interface to exhange data between esp32.
Error:
Begin compiling code for the board DOIT ESP32 DEVKIT V1 ![]()
C:\Users\Ryszard\AppData\Local\Temp\xod_temp_sketchbookdTodmO\xod_1656934278970_sketch\xod_1656934278970_sketch.ino: In member function ‘void xod::xod__uart__uart::Node::evaluate(xod::xod__uart__uart::Node::Context)’:
C:\Users\Ryszard\AppData\Local\Temp\xod_temp_sketchbookdTodmO\xod_1656934278970_sketch\xod_1656934278970_sketch.ino:1095:27: error: ‘SERIAL_PORT_HARDWARE’ was not declared in this scope
auto serial = SERIAL_PORT_HARDWARE;
C:\Users\Ryszard\AppData\Local\Temp\xod_temp_sketchbookdTodmO\xod_1656934278970_sketch\xod_1656934278970_sketch.ino: In member function ‘void xod::xod__core__console_log::Node::evaluate(xod::xod__core__console_log::Node::Context)’:
C:\Users\Ryszard\AppData\Local\Temp\xod_temp_sketchbookdTodmO\xod_1656934278970_sketch\xod_1656934278970_sketch.ino:2393:28: warning: ‘xod::List* xod::List::operator->() [with T = char]’ is deprecated [-Wdeprecated-declarations]
for (auto it = line->iterate(); it; ++it)
C:\Users\Ryszard\AppData\Local\Temp\xod_temp_sketchbookdTodmO\xod_1656934278970_sketch\xod_1656934278970_sketch.ino:248:11: note: declared here
List* operator->() attribute ((deprecated)) { return this; }
Compilation failed
