Hello nkrkv,
in the last xod version your Great “sleep until switch” node make an error during compilation.
Can you solve the problem?
Begin compiling code for the board Arduino Nano
C:\Users\gst\AppData\Local\Temp\xod_temp_sketchbookuFJ5bf\xod_1607753840659_sketch\xod_1607753840659_sketch.ino: In instantiation of ‘void xod::nkrkv__avr_sleep__sleep_until_switch::Node<constant_input_WAKE>::evaluate(xod::nkrkv__avr_sleep__sleep_until_switch::Node<constant_input_WAKE>::Context) [with unsigned char constant_input_WAKE = 2u; xod::nkrkv__avr_sleep__sleep_until_switch::Node<constant_input_WAKE>::Context = xod::nkrkv__avr_sleep__sleep_until_switch::Node<2u>::ContextObject*]’:
C:\Users\gst\AppData\Local\Temp\xod_temp_sketchbookuFJ5bf\xod_1607753840659_sketch\xod_1607753840659_sketch.ino:1275:36: required from here
C:\Users\gst\AppData\Local\Temp\xod_temp_sketchbookuFJ5bf\xod_1607753840659_sketch\xod_1607753840659_sketch.ino:1149:24: error: invalid use of non-static member function
attachInterrupt(g_interruptNum, wakeISR, CHANGE);
Compilation failed
