Hussainfawzi/fast-pwm
Trying to get Fast-PWM to work on a Leonardo!?
Is it only for Uno? Tips?
C:\Users\KYLTON~1.MED\AppData\Local\Temp\xod_temp_sketchbooknRMBtu\xod_1603636495269_sketch\xod_1603636495269_sketch.ino:1225:17: note: suggested alternative: ‘fwrite’
pwmWrite(port, duty);
fwrite
Compilation failed
I was a stupid beginner that was all.
However, I would like a boolean out instead of port, Help!
