How to use flipntimes example please
is their any chance some could show me in an example how to use flipentimes node please?
Did you read the help for the node? It is pretty self explanatory. “How to use it” will depend on what you are trying to do.
Are you trying something that doesn’t seem to work? Share it with us and maybe we can explain what you are doing wrong.
ALL GOOD I FIGURED IT OUT - WRONG CONNECTION ON MY END – UNRELATED QUESTION ON A 2IC LCD THE ADDRESS IS 0X27 ON THE LCD , BUT ON THE XOD NODE ON THE LCD IT 27h , THE LCD NODE DOES NOT ACCEPT 0X27 , DOES ANY ONE KNOW IF THIS IS CORRECT ?
0x## & ##h are both ways to represent hexadecimal numbers (base 16), so 0x27 & 27h would be the same number.
thanks that was help full
