0.25.0 Installer problem
I’m having problem uploading to ESP8266 board (XOD 0.25.0), after selecting “Download & Install” it starts the download then after sometime it ends with error. Appreciate any help.
Installing Arduino dependencies…
Downloading esp8266:esptool@0.4.13…
esp8266:esptool@0.4.13 downloaded
Downloading esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2…
esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2 downloaded
Downloading esp8266:mkspiffs@0.2.0…
esp8266:mkspiffs@0.2.0 downloaded
Downloading esp8266:esp8266@2.4.3…
esp8266:esp8266@2.4.3 downloaded
Installing esp8266:esptool@0.4.13
esp8266:esptool@0.4.13 installed
Installing esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2
runtime: VirtualAlloc of 2097152 bytes failed with errno=487
fatal error: runtime: cannot map pages in arena address space
runtime stack:
runtime.throw(0xa25f89, 0x30)
/home/jenkins/go1.10.2-patched/src/runtime/panic.go:616 +0x6b
runtime.sysMap(0x4cc40000, 0x200000, 0x3478fe01, 0xdb2b58
/home/jenkins/go1.10.2-patched/src/runtime/mem_windows.go:124 +0x100
runtime.(*mheap).sysAlloc(0xda1620, 0x200000, 0x26501)
/home/jenkins/go1.10.2-patched/src/runtime/malloc.go:470 +0x22f
runtime.(*mheap).grow(0xda1620, 0x100, 0x0)
/home/jenkins/go1.10.2-patched/src/runtime/mheap.go:907 +0x4e
runtime.(*mheap).allocSpanLocked(0xda1620, 0x100, 0xdb2b68, 0x1000)
/home/jenkins/go1.10.2-patched/src/runtime/mheap.go:820 +0x2e4
runtime.(*mheap).alloc_m(0xda1620, 0x100, 0xda0101, 0x14ce3)
/home/jenkins/go1.10.2-patched/src/runtime/mheap.go:686 +0x115
runtime.(*mheap).alloc.func1()
/home/jenkins/go1.10.2-patched/src/runtime/mheap.go:753 +0x40
runtime.(*mheap).alloc(0xda1620, 0x100, 0x12010101, 0x0)
/home/jenkins/go1.10.2-patched/src/runtime/mheap.go:752 +0x6c
runtime.largeAlloc(0x1ffe00, 0x440101, 0x1640000)
:826 +0x7b
runtime.mallocgc.func1()
/home/jenkins/go1.10.2-patched/src/runtime/malloc.go:721 +0x39
runtime.systemstack(0x0)
/home/jenkins/go1.10.2-patched/src/runtime/asm_386.s:464 +0x5e
runtime.mstart()
/home/jenkins/go1.10.2-patched/src/runtime/proc.go:1175
goroutine 1 [running]:
runtime.systemstack_switch()
/home/jenkins/go1.10.2-patched/src/runtime/asm_386.s:418 fp=0x12239900 sp=0x122398fc pc=0x44bb10
runtime.mallocgc(0x1ffe00, 0x96be60, 0x12239901, 0x6000)
/home/jenkins/go1.10.2-patched/src/runtime/malloc.go:720 +0x67b fp=0x12239954 sp=0x12239900 pc=0x40e7fb
runtime.makeslice(0x96be60, 0x1ffe00, 0x1ffe00, 0x4ca6a000, 0x649d81, 0x11f461e0)
/home/jenkins/go1.10.2-patched/src/runtime/slice.go:61 +0x59 fp=0x12239968 sp=0x12239954 pc=0x439da9
bytes.makeSlice(0x1ffe00, 0x0, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/bytes/buffer.go:230 +0x61 fp=0x12239984 sp=0x12239968 pc=0x4d6ff1
bytes.(*Buffer).grow(0x11f301e0, 0x200, 0x6000)
/home/jenkins/go1.10.2-patched/src/bytes/buffer.go:144 +0x112 fp=0x122399ac sp=0x12239984 pc=0x4d6a82
bytes.(*Buffer).ReadFrom(0x11f301e0, 0xaa0b40, 0x11e17b00, 0x34b10120, 0x11f301e0, 0x1, 0xe80)
/home/jenkins/go1.10.2-patched/src/bytes/buffer.go:204 +0x45 fp=0x122399e8 sp=0x122399ac pc=0x4d6e35
io.copyBuffer(0xaa0c20, 0x11f301e0, 0xaa0b40, 0x11e17b00, 0x0, 0x0, 0x0, 0x60, 0x9b4b80, 0x1222ba01, …)
/home/jenkins/go1.10.2-patched/src/io/io.go:386 +0x2be fp=0x12239a24 sp=0x122399e8 pc=0x453f6e
io.Copy(0xaa0c20, 0x11f301e0, 0xaa0b40, 0x11e17b00, 0x64, 0x0, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/io/io.go:362 +0x51 fp=0x12239a54 sp=0x12239a24 pc=0x453c81
github.com/arduino/arduino-cli/vendor/github.com/codeclysm/extract.Tar(0xaa1920, 0x11ffdce0, 0x11f29440, 0x35, 0x0, 0xb, 0xa0f90f)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/vendor/github.com/codeclysm/extract/extract.go:168 +0x2bc fp=
0x12239bf4 sp=0x12239a54 pc=0x65f86c
github.com/arduino/arduino-cli/vendor/github.com/codeclysm/extract.Gz(0xaa1920, 0x11ffdc90, 0x11f29440, 0x35, 0x0, 0xb, 0xa0eae4)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/vendor/github.com/codeclysm/extract/extract.go:110 +0x173 fp=0x12239c78 sp=0x12239bf4 pc=0x65f513
github.com/arduino/arduino-cli/vendor/github.com/codeclysm/extract.Archive(0xaa1920, 0x11ffdc90, 0x11f29440, 0x35, 0x0, 0x0, 0x1221a278)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/vendor/github.com/codeclysm/extract/extract.go:65 +0x184 fp=0x12239d00 sp=0x12239c78 pc=0x65f004
github.com/arduino/arduino-cli/arduino/resources.(*DownloadResource).Install(0x12008cc0, 0x11de5ff8, 0x11f6c000, 0x1221a278, 0x0, 0x0)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/arduino/resources/install.go:57 +0x2cb fp=0x12239d68 sp=0x12239d00 pc=0x66299b
github.com/arduino/arduino-cli/arduino/cores/packagemanager.(*PackageManager).InstallTool(0x11f491e0, 0x1200ade0, 0x0, 0x0)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/arduino/cores/packagemanager/install_uninstall.go:85 +0xde fp=0x12239db8 sp=0x12239d68 pc=0x77524e
github.com/arduino/arduino-cli/commands/core.InstallToolRelease(0x11f491e0, 0x1200ade0)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/commands/core/install.go:131 +0x122 fp=0x12239e24 sp=0x12239db8 pc=0x8997e2
github.com/arduino/arduino-cli/commands/core.installPlatformByRef(0x11f491e0, 0x11f491a0)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/commands/core/install.go:72 +0x6c fp=0x12239e58 sp=0x12239e24 pc=0x898f1c
github.com/arduino/arduino-cli/commands/core.runInstallCommand(0x11f58140, 0x11f465d0, 0x1, 0x2)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/commands/core/install.go:54 +0xc4 fp=0x12239e90 sp=0x12239e58 pc=0x898e84
github.com/arduino/arduino-cli/vendor/github.com/spf13/cobra.(*Command).execute(0x11f58140, 0x11f465a0, 0x2, 0x2, 0x11f58140, 0x11f465a0)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/vendor/github.com/spf13/cobra/command.go:760 +0x20e fp=0x12239f04 sp=0x12239e90 pc=0x84fbee
github.com/arduino/arduino-cli/vendor/github.com/spf13/cobra.(*Command).ExecuteC(0x11e712c0, 0x11f588c0, 0x11e71e00, 0x11e71a40)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/vendor/github.com/spf13/cobra/command.go:846 +0x28a fp=0x12239fa0 sp=0x12239f04 pc=0x85050a
github.com/arduino/arduino-cli/vendor/github.com/spf13/cobra.(*Command).Execute(0x11e712c0, 0x8f2718, 0x8f34f4)
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/vendor/github.com/spf13/cobra/command.go:794 +0x21 fp=0x12239fb4 sp=0x12239fa0 pc=0x850261
main.main()
/home/jenkins/workspace/arduino-cli/src/github.com/arduino/arduino-cli/main.go:30 +0x1f fp=0x12239fc8 sp=0x12239fb4 pc=0x8f352f
runtime.main()
/home/jenkins/go1.10.2-patched/src/runtime/proc.go:198 +0x1ea fp=0x12239ff0 sp=0x12239fc8 pc=0x4296aa
runtime.goexit()
/home/jenkins/go1.10.2-patched/src/runtime/asm_386.s:1665 +0x1 fp=0x12239ff4 sp=0x12239ff0 pc=0x44d5f1
goroutine 5 [syscall, 12 minutes]:
os/signal.signal_recv(0x0)
/home/jenkins/go1.10.2-patched/src/runtime/sigqueue.go:139 +0x12f
os/signal.loop()
/home/jenkins/go1.10.2-patched/src/os/signal/signal_unix.go:22 +0x1a
created by os/signal.init.0
/home/jenkins/go1.10.2-patched/src/os/signal/signal_unix.go:28 +0x37
goroutine 152 [IO wait]:
internal/poll.runtime_pollWait(0x321f90e0, 0x72, 0x0)
/home/jenkins/go1.10.2-patched/src/runtime/netpoll.go:173 +0x4b
internal/poll.(*pollDesc).wait(0x121a427c, 0x72, 0xd52100, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/internal/poll/fd_poll_runtime.go:85 +0x8c
internal/poll.(*ioSrv).ExecIO(0xd9c8e0, 0x121a4194, 0xa33f30, 0x40, 0x42b3b0, 0x1215fee8)
/home/jenkins/go1.10.2-patched/src/internal/poll/fd_windows.go:223 +0xf1
internal/poll.(*FD).Read(0x121a4180, 0x1206e000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/internal/poll/fd_windows.go:484 +0x1f0
net.(*netFD).Read(0x121a4180, 0x1206e000, 0x1000, 0x1000, 0x427514, 0xa34334, 0x12233c10)
/home/jenkins/go1.10.2-patched/src/net/fd_windows.go:151 +0x3f
net.(*conn).Read(0x11f6c2d0, 0x1206e000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/net/net.go:
176 +0x56
crypto/tls.(*block).readFromUntil(0x1202fbe0, 0x321f91e0, 0x11f6c2d0, 0x5, 0x11f6c2d0, 0x0)
/home/jenkins/go1.10.2-patched/src/crypto/tls/conn.go:493 +0x76
crypto/tls.(*Conn).readRecord(0x11e16900, 0xa34317, 0x11e169a0, 0x11f6c2d0)
/home/jenkins/go1.10.2-patched/src/crypto/tls/conn.go:595 +0xbd
crypto/tls.(*Conn).Read(0x11e16900, 0x11f7d000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/crypto/tls/conn.go:1156 +0xdd
bufio.(*Reader).Read(0x1207b920, 0x11e64e20, 0x9, 0x9, 0x5b8289, 0x11e16af0, 0xfffffffe)
/home/jenkins/go1.10.2-patched/src/bufio/bufio.go:216 +0x22b
io.ReadAtLeast(0xaa0bc0, 0x1207b920, 0x11e64e20, 0x9, 0x9, 0x9, 0x12230000, 0x164035c, 0x12233dcc)
/home/jenkins/go1.10.2-patched/src/io/io.go:309 +0x68
io.ReadFull(0xaa0bc0, 0x1207b920, 0x11e64e20, 0x9, 0x9, 0x11, 0x1000, 0x11)
/home/jenkins/go1.10.2-patched/src/io/io.go:327 +0x45
net/http.http2readFrameHeader(0x11e64e20, 0x9, 0x9, 0xaa0bc0, 0x1207b920, 0x0, 0x0, 0x0, 0x11e01300, 0x12176090)
/home/jenkins/go1.10.2-patched/src/net/http/h2_bundle.go:1517 +0x66
net/http.(*http2Framer).ReadFrame(0x11e64e00, 0x11fe2160, 0x0, 0x0, 0x0)
/home/jenkins/go1.10.2-patched/src/net/http/h2_bundle.go:1775 +0x82
net/http.(*http2clientConnReadLoop).run(0x12233fdc, 0xa34058, 0x11e21fdc)
/home/jenkins/go1.10.2-patched/src/net/http/h2_bundle.go:8028 +0x6d
net/http.(*http2ClientConn).readLoop(0x11f7a000)
/home/jenkins/go1.10.2-patched/src/net/http/h2_bundle.go:7956 +0x58
created by net/http.(*http2Transport).newClientConn
/home/jenkins/go1.10.2-patched/src/net/http/h2_bundle.go:7143 +0x576
C:\Users\MyName\AppData\Local\Programs\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\MyName\AppData\Local\Temp\arduino-cli719pQb\.cli-config.yml core install esp8266:esp8266 failed with code 2
Looks like a bug in arduino-cli we can’t affect directly. It is an interesting case, let’s try to find a workaround. Here is interesting piece:
Looks like you gone out of RAM. How much RAM do you have on PC? What OS do you have? 64-bit Windows 10, right?
What will happen if you try to repeat “ Download & Install”? The second time some tools are already installed and I wonder will they consume RAM again.
Thanks for your replay,
I tested on 2 PCs:
Dell i7-4900MQ 32GB Windows 10 x64 (1809)
And Lenovo all-in-one i5-4570T 16GB Windows 10 x64 (1809)
Both with no success, I’m reporting from the i7-32GB machine
On next run I’m getting this:
Error: read tcp 192.168.0.4:55504->54.231.72.115:443: wsarecv: An existing connection was forcibly closed by the remote host.
Error downloading esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2
C:\Users\MyName\AppData\Local\Programs\XOD IDE\resources\arduino-cli.exe --config-file=C:\Users\MyName\AppData\Local\Temp\arduino-cli7tcwxz\.cli-config.yml core install esp8266:esp8266 failed with code 5
Impressive PCs! Definitely should not be out-of-memory. I wonder what the following means:
Are you behind a firewall or a corporate proxy? Do you have a chance to retry with “another” internet?
@rutafar, thanks for the report!
It looks like a bug in the arduino-cli, but I can’t reproduce it. :thinking:
Tested on PC: Lenovo i3-4160T 3.1GHz, 4 GB RAM, Windows 10 x64
Try to remove __packages__ directory in your workspace, restart the IDE and then install this package again.
While it will install packages open the Task Manager and take a look on arduino-cli.exe process. How much RAM and CPU it uses? And is it still failing?
If it still failing, you can try to install packages manually.
The easiest way to install packages: install them within Arduino IDE and then copy installed packages into __packages__ directory inside your workspace.
But latest release of esp8266 have a little bug in the platform.txt, so we did a little fix and named this version 2.4.3 (next official release will be 2.5.0) and uploaded it onto our server. So then you can just upgrade your package by selecting Deploy -> Update Packages & Toolchains... menu item.
Many thanks,
Yes, I’m using Zone alarm firewall but no proxy. The good news is that the IDE managed to finish the installation now and I got this message (tested on booth machines, and firewall still ON):
Arduino dependencies installed
Package "esp8266" installed successfully
Now you are able to upload the program
Deployment
Watched Values
InstallerCompilerUploaderDebugger
esp8266:xtensa-lx106-elf-gcc@1.20.0-26-gb404fb9-2 installed
Installing esp8266:mkspiffs@0.2.0
esp8266:mkspiffs@0.2.0 installed
Installing esp8266:esp8266@2.4.3…
esp8266:esp8266@2.4.3 installed
=== All Arduino dependencies are installed successfully ===
Appreciate your help, thanks
Good to hear it!
So you just deleted the __packages__ directory and tried again and it helps? Am I right?
No, I did nothing, only retrying the upload and finally it worked,
Cheers
Phew :smiley:
Thank you for reporting and I hope you’ll enjoy xoding in spite of this error :slight_smile:
