Sleep_mode_standby
node-name
A short description of the node as it should be seen in the docs
Inputs
-Two inputs PULSE and BOOLEAN - in order to exit the STANDBY mode
  • 1 IN PULSE SLP channel - To put into STANDBY mode
Outputs
  • OUT (number) — the description
  • 1 OUT BOOLEAN, FALSE if the board is active. TRUTH when the board is sleeping.
Hello friends! I need a knot to put my NANO board into STANDBY mode. The existing nkrkv / avr-sleep @ 1.0.0 library does not suit me. Since I want to wake up the board from the remote control or a tactile button to choose from. I need STANDBY mode to save the board, it will work from a 220V network and energy saving is not important. An approximate diagram of the node in the picture.Standby
I will gladly accept your suggestions for changing the nodes for wider use.
I think it would not be bad if there was a library with all sleep modes.
SLEEP_MODE_IDLE
SLEEP_MODE_ADC
SLEEP_MODE_PWR_SAVE
SLEEP_MODE_STANDBY
SLEEP_MODE_PWR_DOWN
Everyone could use what suits him.
Answer, at least someone. Should I wait for this library or need to look for other solutions? Tell me, is it possible to change the code and how to do it in the avr-sleep node to get SLEEP_MODE_STANDBY?
