Perforn a Read on SD-Card
#1
SD-Read
Reads lines of text to a file on SD card
Inputs
  • CS (port) - CS (chip select) pin the SD card reader is connected to. Also known as SS (slave select).
  • FILE (string) - File name to read to
  • LINE (number, default=0) - Line to read
  • W (pulse) - Perform line read
Outputs
  • LINE-OUT (string) - Outputs string from line
  • ERR (boolean) - Outputs false if the last write succeed. Set to true if an error occured: wrong connection, missing or bad SD card, write protection.
  • DONE (pulse) - Fires when read is done
Hope anyone could do this, because I can’t get it to work and I think this is also a very good feature. I want to use this to display text to LCD.
Thank you.
#2
Can’t compile
C:\Temp\xod_temp_sketchbook2cEYiZ\xod_1544133635312_sketch\xod_1544133635312_sketch.ino: In function ‘void xod::xod__gpio__pwm_write::evaluate(xod::xod__gpio__pwm_write::Context)’:
C:\Temp\xod_temp_sketchbook2cEYiZ\xod_1544133635312_sketch\xod_1544133635312_sketch.ino:1435:5: error: ‘::analogWrite’ has not been declared
::analogWrite(port, val);
Moderator note :exclamation: Not related to the original topic of the current thread
#3
Hi jmlapido
I have started a library very similar to this with the ability to save and retrieve individual settings and log data from a file. Is this something you would be interested in?
#4
Hi bradzilla84,
Yes, this would be very similar… Hope you could share me that library…
Thank you
#5
Hi mate…
Any update? :slight_smile:
#6
Sorry not yet, I have a fair few projects on the go at the moment and this one will be a bit one.
