Hey cesars
Take a look at this. https://xod.io/libs/bradzilla84/singen/
Gen is easy but the Library doesn’t seam to have a good way the get the value out without altering it.
Hi, now I will look at it, but the alternative generation is automatic, it is already incorporated with pinYuksekPWM and pinAlcakPWM. SinGen(uint8_t pinYuksekPWM = 3, uint8_t pinAlcakPWM = 5, double HzFrekans = 1);
Yeah continuous in XOD is not the same as in Arduino. There is a slight delay while all other nodes are processed. I’m sure there is a way around this I have another patch I’m working on with the same issue.
