Node(s) to use Arduino's internal EEPROM
#1
node-name
  • EEPROM Clear
  • EEPROM Read
  • EEPROM Write
  • EEPROM Crc
  • EEPROM Get
  • [EEPROM Iteration
  • [EEPROM Put
  • EEPROM Update
A set of nodes (or one node) to use eeprom library that comes standard with arduino IDE
https://www.arduino.cc/en/Reference/EEPROM
Inputs
  • the data to be written (number or bytes)
  • the eeprom address to write to or read from
  • a pulse input to read/write the data
Outputs
  • data that was written to eeprom
  • error
  • done
With these nodes we could save new variables to the arduino internal eeprom so that changed values are kept when the board is turned off (like a tiny hard drive).
#2
I created this. Couldn’t test it yet though. If it doesn’t work, maybe it will give you an idea of how to improve it. If it does work, I’m glad I could help. I only implemented read, write and update functions though…
https://xod.io/libs/dancojocaru2000/arduino-eeprom/
#3
Thank you verry much!!!
I didn’t expect a solution that quick after posting. :smile:
I will give it a try right away
#4
Im seeking a node for write a string or an Array of variabile in EEPROM . Im creating an rf 433 receiver/trasmitter for cloning trasmitter of garage and make a trasmitter into my car integrated with dashboard. For make it would receive all variables off rf433 node and store It in eprom for reuse with trasmitter. I love xod but for this work i dont know what Is best approch.
