# File does not exist .Compilation failed
**URL:** <https://forum.xod.io/t/file-does-not-exist-compilation-failed/2920>\
**Category:** Uncategorized\
**Created:** [November 25, 2019, 7:35pm UTC](https://forum.xod.io/t/file-does-not-exist-compilation-failed/2920 "2019-11-25T19:35:02Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![wayland](https://yyz1.discourse-cdn.com/flex027/user_avatar/forum.xod.io/wayland/32/1590_2.png) [@wayland](https://forum.xod.io/u/wayland)\
**Post date:** [November 26, 2019, 9:22am UTC](https://forum.xod.io/t/file-does-not-exist-compilation-failed/2920/5 "2019-11-26T09:22:41Z")
</div>
The spaces in your username (Beelink BT3 Pro) are causing the problem. The developers have fixed this issue in the next release. Try the prerelease version:
> [@Many Many problems After Installing Xod](https://forum.xod.io/t/many-many-problems-after-installing-xod/2784/11):
> @drsaylor I’ve already done with it (PR: [https://github.com/xodio/xod/pull/1906](https://github.com/xodio/xod/pull/1906) ). The fix will be included in the next release. But now you can download the prerelease version (v0.31.2-alpha.be98d789): [https://www.googleapis.com/download/storage/v1/b/releases.xod.io/o/v0.31.2-alpha.be98d789%2FXOD%20IDE%20Setup%200.31.2-alpha.be98d789.exe?generation=1573584233408735&alt=media](https://www.googleapis.com/download/storage/v1/b/releases.xod.io/o/v0.31.2-alpha.be98d789%2FXOD%20IDE%20Setup%200.31.2-alpha.be98d789.exe?generation=1573584233408735&alt=media) Please, write the review about this prerelease to make sure that helps. slight_smile
_[View the full topic](https://forum.xod.io/t/file-does-not-exist-compilation-failed/2920)._
