After uploading some experimental projects to my Arduino (compile in the cloud was always unchecked!) the counter changes its value. It jumps to 988, after a few compilations to 981 and after a restart to 989.
Is this a bug?
If you’re not logged in inside IDE cloud quotas are bind to IP. So if someone in your network does the same, he eats your quota Log in to use personal limits (they are higher and not shared). Reset/replenishment is done daily.
However, the numbers indeed behave strangely. Thanks for pointing it, we’ll take a look.
That’s indeed was a server bug which caused counting by internal server IP rather than real user IP. We’ve fixed it.
