What would be the correct way to clean a value in a node output? as if it were a tri-state.
Any output always containing some value. So, it’s impossible to clean a value.
I can assume that you have some calculations or data that comes from sensors that can occur at different times, and further calculations you want to run only when all data is received.
If so, use Pulse type to evaluate something when data is ready.
